  2. Mixed-Signal Design
  3. Floorplanning Problems in Mixed-Signal Design with Digital...
  • Subscribers 67
  • Views 5186
Floorplanning Problems in Mixed-Signal Design with Digital Block Pins Optimization
Layouter5338
Layouter5338 over 2 years ago
I'm working on floorplanning a mixed-signal design that includes a digital block. I have a couple of questions where I'd appreciate some advice:
1. Auto Placement in Pre-Placed Padring:
  • I have completed some custom blocks and their pads placements, leaving the center of the die empty.
  • My concern is that Virtuoso might treat the entire pad ring as a single big block during auto placement, preventing blocks from being placed in the center.
  • How can I configure the physical hierarchy to allow auto placement within the pad ring?
2. Pin Misalignment During Optimization:
  • I attempted to load physical views of ready blocks, with the unfinished digital block positioned in the center.
  • When I use the pin optimization function, the pins of the (unplaced) digital block don't align with the pins of the loaded blocks that they should be connected to.
  • These blocks share many pin names at the top level and should have aligned pins after pins optimization.
  • Could you advise on troubleshooting this pin alignment issue or provide the correct steps for pin optimization in this scenario?
Thank you in advance for your assistance
