  2. Mixed-Signal Design
  3. [AMS][xrun: Command not found]
  • Subscribers 67
  • Views 4451
IssacW
IssacW over 2 years ago
dear all,
A new warning regarding "Xcelium" occurs after our Linux env. update, as shown in the next thread. so I believe this should be something related to the environment variable setup.
also shown in the same picture, the path of "xrun" has been clearly identified by cadence so is there any explanation about this discontinuity, or any further setup to help cadence evoke "xrun"?
look forward to your opinions. many thanks.
  • IssacW
    Andrew Beckett over 2 years ago in reply to IssacW
    What is the content of /etc/os-release ?
    My guess is that you are running an OS that only supports 64-bit executables. So perhaps try running "xrun -64 -version" and see if that works. If it does, you could use:
    setenv CDS_AUTO_64BIT ALL
    or
    export CDS_AUTO_64BIT=ALL
    (depending on your shell) and then:
    xrun -version
    should work.
  • IssacW
    IssacW over 2 years ago in reply to Andrew Beckett
    hi Andrew,
    that it is! now it works by referring to the "xrun" under folder "64bit".
    I'm the first one working in AMS flow in our group so have got a ways to go in understanding Xcelium. anyway thanks.
