  2. Mixed-Signal Design
  3. spectre simulation issue
  • Subscribers 67
  • Views 5380
YH202410112147
YH202410112147 over 2 years ago
There is a problem during the post layout simulation process.
I am extracting and simulating post nets in DSPF file format. I probed the output node with a script to probe the desired node in post net.
Also, I can confirm that the probe was run normally in the output log. However, the probed output waveform does not appear in the result browser.
What is causing this problem?
script based probing
output log
example of post net
result browser (can't show probe signal)
  • YH202410112147
    output log
    example of post net
