  2. Mixed-Signal Design
  3. Smith Chart S11 value
  • Subscribers 67
  • Views 7893
mxm14
mxm14 over 2 years ago
I m simulating the following circuit for trying to understand smith chart parameters on virtuoso:
and extracting Z and S parameters:
I hilighted here the value of S11 @30G.
i then plotted S11 on the smith chart:
And i have different values for S11 respect to the previous one:529.6m+j254.9m. I was wondering: how this values are related?
  • mxm14
    Andrew Beckett over 2 years ago in reply to mxm14
    You're not plotting the same thing. Your s-parameters in the output pane are the real and imaginary values of the cartesian coordinates of the s-parameters, whereas the marker on the graph is showing the s-parameters transformed onto the Smith chart and are showing the normalised impedance (normalised to 50 Ohms). You can change the markers by using right mouse button over the graph and changing the Smith Chart Properties:
    Then by adding %C, you can then also see the Cartesian coordinates which do match. For more information, look up Smith Charts on Wikipedia, or any number of RF texts (e.g. Fields and Waves in Communications Electronics: Ramp Whinnery and Van Duzer).
  • mxm14
    mxm14 over 1 year ago in reply to Andrew Beckett
    Thank you Andrew!So the values on the Smith chart are related to th eimpedance normalised to 50ohm.
    If i consider the Z11 value @30G I got
    Shouldn those be related to the Z i read from the smith chart?
