  2. Mixed-Signal Design
  3. Deepprobe to connect to a bus (extracted view)
  • Subscribers 68
  • Views 5546
Macio
Macio over 1 year ago
I would like to know if deepprobe supports bus notation in extracted view. As an example:
Top level cell: I0
Cell inside I0: I1
Bus to be probed in I1: net<0:3>
As long as the number of bits is consistent between the instance and the hierarchical node it works (picture below):
When extracting, the net name changes and the probeNode should be adjusted accordingly, however I am not able to find a proper way to do it.
I would like to consider two cases:
- only I1 is extracted and I0 is schematic
- The whole I0 is extracted
I am working with DSPF files and was able to probe single nets within extracted blocks as described in: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009F8LPEA0&pageName=ArticleContent
but was not able to repeat it for buses.
Virtuoso sub version: IC23.1-64b.ISR12.37
Thank you,
Maciej
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago
    Have you already seen https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1OPP0000011ABF2A2 ?
