  2. Mixed-Signal Design
  3. Issue on Running simulation with VerilogA and SystemVerilog...
  • Subscribers 65
  • Views 1094
Issue on Running simulation with VerilogA and SystemVerilog in virtuoso - Z output
AmirMasnadi
AmirMasnadi 7 months ago
I am trying to run an AMS sim in virtuoso where I do have a systemVerilog block and verilogA block instantiated in schematic view.  Each block works fine stand alone but when I make a testbench together the verilogA output is all Z . Any idea what is wrong ?
  • engineer27
    engineer27 5 months ago
    Check your discipline resolution. You may need "detailed" resolution. If you did not set it explicitly, you are likely using "default."
    Here are a couple of articles that address the topic:
    Article (20498260) Title: How are disciplines assigned/resolved in mixed-signal simulation during elaboration?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009EqUZEA0
    Article (20485101) Title: Mixed Signal Verification - Connectivity Overview
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006DfnQUAS
