  2. Mixed-Signal Design
  3. Netlisting error
  • Subscribers 68
  • Views 5783
Netlisting error
PE202503078250
PE202503078250 over 1 year ago
I'm using Virtuoso version 'ICADVM20.1-64b.500.27
I'm running a simulation , choosing 'ams' as the simulator. When I simulate after adding a certain standard cell from my PDK (GF 22FDSOI), I get the below netlisting error:
"*Error* nmpIsLegalVerilogAMS: argument #1 should be a string (type template = "t") - nil
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
*ERROR* (AMS-1245): AMS UNL netlisting has failed because of errors in the design.
Right-click the test name on the Outputs assistant pane
and check Output Log->Netlister Log for errors.
Correct your design and netlist again.
...unsuccessful.
*Error* failed at creating netlist"
The netlister log has only the below info:
INFO (VLOGNET-60): The stimulus name mapped table will not be printed in the
"/sim/**/netlist/digital/testfixture.verilog" file. To print the stimulus name mapped table, set
simVerilogPrintStimulusNameMappingTable = t either in CIW or the .simrc file
before invoking Verilog netlister.
INFO (VLOGNET-62): Database internal net names will be printed for floating
instance ports. To prevent
them from being printed, set
simVerilogProcessNullPorts = t either in CIW or
the .simrc file.
INFO (VLOGNET-64): All cellviews in the design will be printed in the Netlist
Configuration list.
If you want to print only those cellviews that need to be
re-netlisted in the
list, set simVerilogIncrementalNetlistConfigList = t either
in CIW or the
.simrc file.
INFO (VLOGNET-68): The initial state of stimulus of all inout pins is set to
"z". To get inout
pins with initial state of "0", set
hnlVerilogIOInitStimulusStr = "0"
either in CIW or the .simrc file.
WARNING (OSSHNL-941): Failed to open the sameCellNamesInMultipleLibs file
'/sim/**/netlist/digital/ihnl/sameCellNamesInMultipleLibs', in the append mode.
Ensure that you have the write permission
for the mentioned file.
INFO (VLOGNET-118): Using connection by name (explicit connections) for all
stopping and
non-stopping cells.
How do I debug the error ?
