  2. Mixed-Signal Design
  3. rand_bit_stream not reproducible across runs despite setting...
  • Subscribers 68
  • Views 2113
rand_bit_stream not reproducible across runs despite setting seed
MB202509174350
MB202509174350 over 1 year ago
Hi all,
I am building an LVDS RX and so needed a block to supply random data. Virtuoso ADE has a built-in Verilog-A cell called rand_bit_stream.
Even though you can set a seed value, it seems to ignore it. Different simulation runs have a totally different waveform.
Is this a known problem, or am I doing something wrong?
I am using VIrtuoso IC23.1 and Spectre 23.1.0.477.isr8 64bit.
