  2. Mixed-Signal Design
  3. IC6.1.8: Introduction to AMS Designer Simulation ( 10 Oct...
  • Subscribers 67
  • Views 2228
IC6.1.8: Introduction to AMS Designer Simulation ( 10 Oct 2025) - RAK : Issue of NMOS and PMOS transistor not in its range of parameters
CM202508086341
CM202508086341 over 1 year ago
I recently downloaded a RAK for AMS simulation, and I followed the instructions up to the netlisting phase, which was successful. However, during simulation, an error occurred indicating that the M0 (NMOS) and M1 (PMOS) transistors in the inverter had their length, width, or area values outside the specified range of lmax-lmin, among other issues.
    I just quickly went through the steps in the RAK until pressing the run button on page 28, and it runs successfully for me (I'm using a newer XCELIUM and SPECTRE version but that really shouldn't matter).
    Please check two things:
    1. In the netlist (Simulation->Netlist->Display) does the inv module look like this: (particularly the w and l values):
      module inv (Y, A);
      output Y;
      input A;
      wire (*
      integer inh_conn_prop_name = "bulk_n";
      integer inh_conn_def_value = "cds_globals.\\gnd! "; *)
      \bulk_n_gnd! ;
      wire (*
      integer inh_conn_prop_name = "bulk_p";
      integer inh_conn_def_value = "cds_globals.\\vdd! "; *)
      \bulk_p_vdd! ;
      nmos1 #(.w(1e-06), .l(1.8e-07)) M1 (Y, A, cds_globals.\gnd! , \bulk_n_gnd! );
      pmos1 #(.w(2e-06), .l(1.8e-07)) M0 (Y, A, cds_globals.\vdd! , \bulk_p_vdd! );
      endmodule
    2. Please check Simulation->Options->Analog(Spectre) on the Component tab. Check that scale and scalem are both 1 (not 1u for example). I could get it to fail with 1u (for scale). The default should be 1, but maybe in your environment it's changed?
  • CM202508086341
    CM202508086341 over 1 year ago in reply to Andrew Beckett
    Thanks, the scalem was set to 1u, that is the issue.
