  2. Mixed-Signal Design
  3. AMS: how to probe signals in ADE from a schematic instantiated...
  • Subscribers 67
  • Views 860
AMS: how to probe signals in ADE from a schematic instantiated within a system verilog module
MC20250412421
MC20250412421 5 months ago
Hello everyone !
I have the following hierarchy for my testbench (from highest to lowest level):
1) a schematic view for my testbench which instantiates a systemverilog instance named DUT
2) inside DUT, I have instantiated a schematic cellview with the following systemverilog syntax:
myModule my_module_inst0 (
    .input_A (signal_A)
3) inside my_module_inst0 I have a simple schematic with a few analog signals and dc/tran sources, for example there is a net named my_net.
Now my question is: how do I probe my_net inside ADE ?
With any standard schematic hierarchy I would simply click on "Add new output" and then write "/DUT/my_module_inst0/my_net" to probe the voltage signal of that net however I tried that and it simply does not find that net.
My simulation does work and does output correct signals at the toplevel so I know the connect modules work. Also, I had to add args -ams_ucm and -sv_ms to my test to the additional arguments in the AMS options for the simulation to work.
I also checked in the config view that the hierarchy was indeed correct so that should be fine.
I am using version IC23.1-64b.ISR8.40 of virtuoso and xrun 23.03-s011.
Seems like it should be quite a basic question unfortunately I did not find the answer in the documentation or the forums so I would be very grateful if anyone could help me out with that.
Thanks in advance and have a great day !
Mike
  • MC20250412421
    MC20250412421 4 months ago +2
    Anyone has an idea ? I didn't find anything in the docs about this.
  • MC20250412421
    • Vote Up +2 Vote Down
