  3. "Ref_Des" alignment of data, "place.txt" wanted in the file...
  • Views 868
min sook
min sook over 15 years ago
example)
UUNITS = MILS
D6                    362.50        4712.50        0    DO-214AB         REF_Des    x-loc   y-loc   rotate
 Any other way  ....
  • oldmouldy
    oldmouldy over 15 years ago
    The place_txt.txt has a specific format for import / export of Placement data:
    Refdes<white_space>XLoc<white_space>YLoc<white_space>Rotation<white_space>Mirror<white_space>Footprint
    Try Tools>Reports, New / Edit to write a new report for the parameters that you need - The standard Component Report might fit the bill but the "place_txt.txt" has a fixed format.
  • min sook
    import (placement and Refdes)
    export (placement and Refdes)
    Another way
    skill ???
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    Yes, using skill you would be able to do anything you want with output data.
    you can use normal printf functionality with text left/rigth aligned - also set a specific number of characters etc. for text
    printf("%5s" "text") - will print 5 characters
    printf("%-5s" "text") - will print 5 characters that are left aligned
    etc.
    Best regards
    Ole
