  3. Manual route problem - PCB Editor V16.3
  • Views 1414
shangwu
shangwu over 14 years ago
I’m trying to route some traces manually.  However, it’s really hard to connect to the centers between pads (shows the triangular symbol indicating it’s not connected).  I have to zoom in a lot and sometimes it still does not “latch” to the center of the pad/pin.  I tried gridless, but does not help.  Most of time I can right click and choose finish to have it connected, but does not always work.  Is there any better solution on this?
Thanks.
  • redwire
    redwire over 14 years ago
     Make sure you have the proper objects selected in the options window.   If you have all objects turned off Allegro will never snap to the pins/vias/clines...
  • shangwu
     Yes, that was the problem.  Thank you.
  • ClydeS
    ClydeS over 14 years ago
    Where do I find the "options" window?
  • BillZ
    BillZ over 14 years ago
    Hi
    The Options tab is located down the right side of the frame by default.
    It is a Fold away tab.
    If its missing go to View>Reset Ui to Cadence default
    BillZ
    EMA Design Automation
