  3. Useful PCB calculators.
  • Replies 8
  • Subscribers 161
  • Views 29982
archive over 19 years ago
Hello All,
I have prepared an useful PCB spreadsheet ,Which contains the following most useful PCB calculators.The calculators have been designed to work the best to our knowledge.
Kindly find the attachment Pcb_calci_satya_20071112.xls.
Please inform if any errors or omissions found.The spreadsheet contains the following PCB calculators:
1.Trace Current Calci-----------------Gives trace width based on the current and temperature rating.
2.Via Current Calci--------------------Gives Via size based on the current and temperature rating.
3.Rise time-Max length Calci--------Gives maximum PCB trace length based on rise time and
                                                      dielectric constant of material.
4.Trace Spacing Calci-----------------Gives trace spacing based on the voltage rating.
5.Pad Stack Calculator---------------Gives Padstack features based on the Finished hole diameter.
6.FR4 Impedance Distortion Calc---Gives how impedance value distorts based on rise time and
7.Thermal Copper Area Calci--------Gives copper surface area to cool a device based on its power
                                                       dissipation.
8.AT&S PCB Standards---------------Gives AT&S PCB manufacturing Standards.
9.ICE Calculation----------------------Computes ICE and board density.calculation based on the
                                                       number of pins.
10.Job Quote Calculator--------------In progress.
Your feed backs are most welcome to correct and improve the same.
Satya
AT&S Ecad
Originally posted in cdnusers.org by satya1234
    archive over 18 years ago
    Looks good !!!!
    Dumarjo
    Originally posted in cdnusers.org by dumarjo
    Hi there. This one is NOT mine, thus i do not want credits for it, but still it is a powerfull tool and i would like to share it with You. And it is freeware. http://www.miscel.dk Sincerely Klavs Rommedahl
    Originally posted in cdnusers.org by Malmir
    Hi, Where can I find the attachment
    Originally posted in cdnusers.org by sudha
    Hi Sudha.
    Sorry there are no one, cause it is to big to be permitted for attatching. Thus i provided a web site at the bottom of that web site You should find the "download now" link.
    Give it a chance it is rather good.
    Rgds
    Klavs Rommedahl.
    Hi Malmir,
    I could not able to open "http://www.miscel.dk".
    Its is displaying the following error,can you double check it?
    "HKJ's homepage
    This website is my corner of the world, I am using it to present some of my work. Descriptions in english leads to english pages.
    Denne webside er mit hjørne i verden, jeg bruger den til at vise noget af mit arbejde. Beskrivelse på dansk fører til danske sider.
    MiscEl - A program with lots of electronic calculaton
    Other programs - Other programs that I am giving away
    Elektronik butikker - Links til danske elektronikbutikker og andet elektronik relateret
    To email me with comments/For at skrive til mig: info@miscel.dk "
    Satya
