  3. Useful PCB calculators.
  • Replies 8
  • Subscribers 163
  • Views 25182
archive over 18 years ago
Hello All,
I have prepared an useful PCB spreadsheet ,Which contains the following most useful PCB calculators.The calculators have been designed to work the best to our knowledge.
Kindly find the attachment Pcb_calci_satya_20071112.xls.
Please inform if any errors or omissions found.The spreadsheet contains the following PCB calculators:
1.Trace Current Calci-----------------Gives trace width based on the current and temperature rating.
2.Via Current Calci--------------------Gives Via size based on the current and temperature rating.
3.Rise time-Max length Calci--------Gives maximum PCB trace length based on rise time and
                                                      dielectric constant of material.
4.Trace Spacing Calci-----------------Gives trace spacing based on the voltage rating.
5.Pad Stack Calculator---------------Gives Padstack features based on the Finished hole diameter.
6.FR4 Impedance Distortion Calc---Gives how impedance value distorts based on rise time and
7.Thermal Copper Area Calci--------Gives copper surface area to cool a device based on its power
                                                       dissipation.
8.AT&S PCB Standards---------------Gives AT&S PCB manufacturing Standards.
9.ICE Calculation----------------------Computes ICE and board density.calculation based on the
                                                       number of pins.
10.Job Quote Calculator--------------In progress.
Your feed backs are most welcome to correct and improve the same.
Satya
AT&S Ecad
Originally posted in cdnusers.org by satya1234
    archive over 17 years ago
    Hello Satya, just click on [u]MiscEl - A program with lots of electronic calculaton[/u] and click on [u]MiscEl[/u] located at the bottom left corner of the page.
    Hello Malmir, thankyou so much. It's very powerful tool.
    Originally posted in cdnusers.org by shiva
    Wow!!!!!!!!!!! Great tool.
    Thank you shiva.
    Satya
    Very useful.
    thank you shiva
    Originally posted in cdnusers.org by Moller
