  3. Cutting CLINES - 'scalpel'
  • Replies 7
  • Subscribers 160
  • Views 5692
archive over 19 years ago
---  SCALPEL  ----
This utility will cut a path through Clines, according to a path you draw.
It is a little different from other cutting utilities, in the fact you are not limited to drawing a box or a closed polygon.
Clines are cut with a 12mil (or 0.3mm) gap, although you can define the width yourself.
After loading, type one of the following:
scalpel
   to draw a path, or
scalpel help
   to see the options
This program is not that complex but it does give a good example of how to control programs with the mouse, among a few other things.
Richard Moffat
PCB CAD Manager
Copyright Allied Telesis Labs (NZ) 2006
Originally posted in cdnusers.org by Richard Moffat
scalpel.il
    archive over 18 years ago
    Minor problem with scalpel.il - very last line contains an illegal character, may be just a C/R (shows up as a square in wordpad, a space in Notepad, and "NUL" in Notepad++. Whichever it stops the file from loading, but just edit and remove that last line and it works very nicely.
    Keith Sheach ST Microelectronics.
    E- SYNTAX ERROR found at line 429 column 1 of file scalpel.il
    E- *Error* lineread/read: syntax error encountered in input
    E- *Error* load: error while loading file - "scalpel.il"
    Originally posted in cdnusers.org by ksheach
  • Edmond
    Edmond over 16 years ago
     Can you please reupload scalpel.il? The link does not work.
    Edmond
  • FormerMember
    FormerMember over 14 years ago
     Hi Richard:
    scalpel is a great tool.
    Can it be modified to add the removal of all traces within the boundry ?
    Les
  • ashok123
    ashok123 over 14 years ago
    it is a great tool.. thx for the tool...
  • Khurana
    Khurana over 14 years ago
    Why/when would you want to do this?
