  2. RF Design
  3. "Incorrect Instance Error" while running LVS
  • Subscribers 64
  • Views 3599
auatai
auatai over 16 years ago
Hi all,
I am designing a LC VCO in 130 nm. I have used a L_SY20K_RFVIL inductor from the umc13mmrf library. However, I get a LVS error saying "Incorrect Instance" with reference to the inductor.
 What do I need to to do to clear this ?
thanks in advance
Anurag
  • Quek
    Quek over 16 years ago
    Hi Anurag
    This might be a little late but if the problem is still there ... May I know the lvs tool which you are using? E.g. Diva, Assura, PVS, etc. Would you please upload the log file showing the error?
    Best regards
    Quek
  • auatai
    Hi Quek,
    thanks for the response, but the issue has been settled.
     best regards
     Anurag
  • salar1991
    salar1991 over 8 years ago in reply to auatai
    hi i have the same problem can you tell me how you solved it if you are still available ?
