  2. RF Design
  3. RFLib Mixer Verilog-A model IIP3 simulation Issues
  • Subscribers 64
  • Views 17895
RFQuery
RFQuery over 15 years ago
I was simulating the Mixer model in Verilog-a given in rfLib.
It is terminated with ports of 50 ohm at its input and output.
I did PSS and PAC simulation to find the IIP3 of the Mixer. I used Mixer Gain=20dB, LO power=10 dBm, Input Resistance = 50 Ohm, Output Resistance=50 Ohm Input referred IIP3=13dBm, All Isolation (from LO-RF...etc) = 50dB.
But the IIP3 curve is NOT giving the desired IIP3 = 13 dBm. The 1st Harmonic curve is almost Flat. I have attached the  waveform file
  • RFQuery
     I am also attaching theNetlist file.
    • input_scs.txt
  • RFQuery
    The schematic file is attached
  • adriancb
    adriancb over 14 years ago
         Have you ever received any feedback on this thread?Thanks.
