  2. RF Design
  3. [Help] About the simulation of Wien-bridge OSC.
  • Subscribers 63
  • Views 17624
xxgenerall
xxgenerall over 12 years ago
The Wien-bridge OSC is as below.
R=1K Ohms, C=1uF, so f=1/(2*pi*R*C)=159Hz. And the BW of the operational amplifier is 9KHz. Theoretically, the OSC outputs a sine wave.
However, the OSC keeps a common voltage, which is another steady state.
Is there something wrong with my simulation setup? Can you help me, please? Thanks a lot.
    Whilst it is lovely to see a picture of your circuit, I assume there was a reason you shared it rather than just wanting everyone to admire your handiwork?
  • xxgenerall
    Sorry, Mr. Bechett.
    There was a problem with my computer. Network speed was so low, and I had to wait for some time to reedit my post.
    My post was updated right now. Looking forward to your help.
    Thank you in advance.
    I created a circuit similar to use (using opamp from ahdlLib), with the key point that I stepped the supply from 0 to 3.3 near the beginning of time to give the circuit a "kick". I also arranged that the vcom node is half the supply by using a vcvs.
    Without this, the circuit settled to a metastable state and wouldn't oscillate (that's what it looks like is happening for you).
    Here's the output waveform:
    And here's the schematic (I've included the input.scs so you can see the component values):
    // Generated for: spectre
    // Generated on: Apr 14 23:38:46 2014
    // Design library name: mylib
    // Design cell name: wienBridgeOsc
    simulator lang=spectre
    global 0
    // Library name: mylib
    // Cell name: wienBridgeOsc
    // View name: schematic
    I0 (op vcom net3 net4 vdd 0) opamp gain=100000 freq_unitygain=1M
    R3 (net3 vcom) resistor r=1K
    R2 (op net10) resistor r=1K
    R1 (op net4) resistor r=2.5K
    R0 (net4 vcom) resistor r=1K
    C1 (net3 vcom) capacitor c=1u
    C0 (net10 net3) capacitor c=1u
    E0 (vcom 0 vdd 0) vcvs gain=0.5
    V0 (vdd 0) vsource type=pulse val0=0 val1=3.3 delay=1n rise=10n
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    dcOp dc force=all write="spectre.dc" maxiters=150 maxsteps=10000 \
        annotate=status
    dcOpInfo info what=oppoint where=rawfile
    tran tran stop=100m maxstep=0.1m write="spectre.ic" \
        writefinal="spectre.fc" annotate=status maxiters=5
    subckts info what=subckts  where=rawfile
    ahdl_include "/export/home/apps/IC615_isr/tools/dfII/samples/artist/ahdlLib/opamp/veriloga/veriloga.va"
  • xxgenerall
    Thank you so much, Mr. Beckett.
    I set the initial voltage of a cap to be non-zero with a DC supply. The OSC oscillated.
    I shall try to use your method, Mr. Beckett.
    Thank you.
