  2. RF Design
  3. How to disable the thermal noise but not flicker noise in...
  • Subscribers 63
  • Views 18339
How to disable the thermal noise but not flicker noise in SpectreRF
RFStuff
RFStuff over 10 years ago
Dear all,
Is there any way to disable the thermal noise but not flicker noise in SpectreRF ?
    Not as far as I know, at least not without altering the model parameters on the devices. Why do you want to do this rather than using the noise contributions to assess the amount of contribution of different noise types?
  • RFStuff
    Dear Andrew,
    Thnaks for your reply.
    In MOS model file one can disable flicker noise by making kf(BSIM4) or noia,noib,noic(for BSIM3v3) to ZERO.
    Can you tell us how it can be done for disabling thermal noise in MOS ?
    For bsim4 you have these parameters (from spectre -h bsim4)
    444 tnoia=1.5 Coefficient of channel-length dependence of total channel thermal noise.
    445 tnoib=3.5 Coefficient of channel-length dependence of total channel thermal noise.
    446 tnoic=0.0 Thermal noise parameter.
    447 rnoia=0.577 Thermal noise coefficient.
    448 rnoib=0.5164 Thermal noise coefficient.
    449 rnoic=0.395 Thermal noise coefficient
    For bsim3v3, you have:
    248 gamma=2.0/3.0 Thermal noise coefficient.
    250 gdsnoi=1.0 Channel thermal noise coefficient for 49 noise.
    I have no idea whether messing with these parameters will do what you want. Suck it and see, I guess!
  • RFStuff
    Dear Andrew,
    Thanks for your suggestions.
    I checked the "Virtuoso Simulator Components and Device Model Parameters" file (2014 October).
    I just got confused.
    For BSIM3v3 model the noise model parameters are from 206 to 228 which is different from what you have mentioned.
    Could you please confirm why I am seeing something different numbers (is it I am seeing wrong documents)
    Kind Regards,
    Other than you looking at an old version of the manuals, the main problem is that the PDF is out of sync with the simulator. I was using "spectre -h bsim3v3" instead:
    UNIX> spectre -h bsim3v3 | grep -i noise
    13 isnoisy=yes Should device generate noise. Possible values are no
    Noise model parameters:
    237 noimod=1 Noise model selector.
    238 kf=0 Flicker (1/f) noise coefficient.
    239 af=1 Flicker (1/f) noise exponent.
    240 ef=1 Flicker (1/f) noise frequency exponent.
    244 noid=2e14 flicker noise subthreshold-above threshold transition
    245 wnoi=1e-5 m Channel width at which noise parameters were
    247 flkmod=0 Flicker noise model (0 for Ids based model, 1 for gm
    249 nlev=2.0 49 noise selector.
    251 lintnoi=0 m Lint offset for noise calculation.
