  2. RF Design
  3. Stability analysis of PLL
  • Subscribers 63
  • Views 22636
SwapnaS
SwapnaS over 9 years ago
I am designing a PLL and I want to plot the frequency response of it.  I have chosen to plot it using STB analysis in cadence. So what I have done is I did break the feedback loop from frequency divider to PFD and inserted a probe. I have the figure which shows how I have given the inputs. But the output that I get is as given below which is incorrect. My question is, Is it the correct way to plot the frequency response of pll? If it is then where am I going wrong? What should I modify for a proper output?
    This won't work. The stb analysis is a small signal analysis around a particular bias point (operating point). Almost certainly your PLL doesn't have a small signal loop gain - so this can't work.
    You might want to look at this PLL Verification Workshop (one of our Rapid Adoption Kits) to help guide you with approaches for PLL verification.
  • Rena
    Rena over 7 years ago in reply to Andrew Beckett
    Hello Andrew,
    I'm facing the similar problem.. I'm not getting how to do stability analysis for PLL. I couldn't able to access the link (PLL verification Workshop) which you have given above to check.
    Andrew Beckett over 7 years ago in reply to Rena
    If you are a maintained customer, you should be able to register with the support site for access. If you are a University student, you will need to get your university program contact (probably the relevant professor) to do this as they have the link. If you're under the Europractice scheme, then you may need to contact Europractice to find out how to get your login.
    Kind Regards,
  • Rena
    Hello Andrew
    Now I got the required login credentials and I could able to login, after accepting the license agreement and tried to access the above mentioned link, i'm getting the following error
    The content you are trying to access has been retired and is no longer available."
    Here's a link to the current versions:
    PLL Verification
    PLL Verification (Using ADE Explorer and XCELIUM)
