  2. RF Design
  3. How to save PSP analyses result into an sNp file?
  • Subscribers 63
  • Views 19862
ZoltanT
ZoltanT over 8 years ago
I have found no way to save the S-parameters of a PSP analysis directly. In ViVA we can not really plot a complex waveform, since we have only two dimensions, so exporting a trace will not work. I think that is why the SP analyses had an option for output file. Unfortunately PSP does not have this. Opening the Results browser and selecting export for S11, I got the very same dialog as for exporting a trace, i.e. no Snp file.
I have a circuit, which has a periodic behaviour and I want to compare my simulation data with the measurement one. It would be much more easier to compare two sNp files.
PS: of course I could export the magnitude and the phase into a vcsv file and write a program which converts it into S parameter and then dump it into sNp file. I am looking for a ready to use solution. There must be such an option, I just don't find it.
    Andrew Beckett over 8 years ago +1
    This is supported if using SPECTRE16.1 ISR3 or later (I think that was it), and the environment supports it from IC617 ISR11 onwards. There's now a "file" parameter on the options form for psp and hbsp…
    This is supported if using SPECTRE16.1 ISR3 or later (I think that was it), and the environment supports it from IC617 ISR11 onwards. There's now a "file" parameter on the options form for psp and hbsp:
    Which sub-version of the IC tools (Help->About in the CIW) are you using? Which spectre sub-version (this will be at the top of the simulator log file)?
  • ZoltanT
    ZoltanT over 8 years ago in reply to Andrew Beckett
    I am using ICADV 12.2 and spectre 15.1 currently. Sorry, I forgot to write it in the post. I guess I have to wait for tool upgrade to use that. It is good to know that this feature has been implemented.
    Best regards,
    Zoltan
    Andrew Beckett over 8 years ago in reply to ZoltanT
    Hi Zoltan,
    OK - so you're not too far away from a supported version. If you can at least move to the newer spectre, then you could always add file="blah.s2p" (or whatever you want to call it) in the Additional Parameters field on the psp options form. You could do that without changing the IC version - so may be less disruptive to your flow.
    Kind Regards,
