  2. RF Design
  3. substrate layer of inductor
  • Subscribers 63
  • Views 17960
yefJ
yefJ over 7 years ago
Hello, I have built an inductor as shown bellow, there are  two layers layer 9 and layer 8  with a VIA connecting between them.
 There are 3 layers where a substrate could be defined.under layer 9, between layer 9 and layer 8 and above layer 8.
The only option i have is to load a file , but can i define it manualy some how?
    Momentum is a tool from Keysight, not Cadence (see the banner of the Momentum window). You would be better off asking this question to Keysight - either their customer support or here: https://community.keysight.com/community/discussion-forums/eda-software
  • yefJ
    yefJ over 7 years ago in reply to Andrew Beckett
    yes , thank you very much.
  • yefJ
    yefJ over 7 years ago in reply to yefJ
    Hello Andrew, i didnt mean to ask questions that are not the subject ofthe forum because it was semi cases.every semi case i adressed to Keysight site you said.
    Could you please help me with the injection lock issue.when i tried to post it, it showed that my post is spam.
    Andrew Beckett over 7 years ago in reply to yefJ
    I have no idea what you mean by "because it was semi cases".
    I have found your other posts in moderation - normally I don't get notified unless you appeal the moderation (which you didn't do) - it had put them into moderation because of repeated text in the posts, which is often a sign of spam. Anyway, I've taken them both out of moderation and approved them.
