  2. RF Design
  3. cadence ADE EXPLORER vs MAESTRO
  • Replies 8
  • Subscribers 63
  • Views 32532
robert 21
robert 21 over 6 years ago
Hello, i saw that MAESTRO is a plotting addon is it a part of ADE EXPLORER?
i cant see the relation between the two.i started to read manual and regarding MAESTRO i only see code.
is there some simple examples?
Thanks.
    Maestro is not a plotting add on. Maestro is the name of the view type used to store the setups for ADE Explorer and Assembler, and often used as a generic term to encapsulate ADE Explorer and Assembler. So you would save your simulation setup in a "maestro" view.
    There are some specific SKILL functions (that have the prefix "mae") to make automation related to maestro tools (Explorer and Assembler) easier, but that's not "maestro" either.
    Put another way, maestro is not a distinct thing - it is the same as Explorer and Assembler.
  • robert 21
    robert 21 over 6 years ago in reply to Andrew Beckett
    is there some basic manual with examples?
  • Tawna
    Tawna over 6 years ago
    If you are looking for examples of using ADE Explorer (maestro) with RF Designs, we have many.   This is documented in Article 20463330:
    SpectreRF AppNotes and Tutorials - One of our best kept secrets!
    RF_Doc_Database
    Documentation can be found here:  Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer Workshop -- Introduction - Using SpectreRF from the MMSIM Hierarchy
    ​Workshop Database is located here:  <SPECTRE17.1 or 18.1>/tools.lnx86/spectre/examples/SpectreRF_workshop/RF_Doc_Database.tar.gz
    SpectreRF Workshop 18.1 (later ISRs) and 19.1
    Located in <SPECTRE18.1>/tools.lnx86/spectre/examples/SpectreRF_workshop/spectrerf_workshop_18.1.tar.gz
  • robert 21
    robert 21 over 6 years ago in reply to Tawna
    Hello Tawna, i tried to enter those links,it says to enter some hostID which i think is for premium cadence users.
    is there a way to read these manual with regular links?
    Thanks.
    Andrew Beckett over 6 years ago in reply to robert 21
    It's not a matter of "premium cadence users". All customers with maintenance can have support.cadence.com access, including universities. There's a mechanism via the university program by which users can have access to a "light" account for support (which can access the documents, but can't log support requests; these have to go via one of the university contacts or in the case of the Europractice scheme, via Europractice themselves).
    Anyway, the databases that Tawna mentions are in the SPECTRE installation. The second document can be found by running <SPECTREinstDir>/bin/cdnshelp - it's also on the support site, but also is shipped with the software. The first document that Tawna mentions is really just an overview of what's available.
    However, it's not really clear what you were asking for when you asked:
    A manual about what? Examples of what? As part of the cdnshelp that I mention above, there are manuals galore - I really don't know what you're looking for. If you can create a support account via your institution, there are also lots of Rapid Adoption Kits available too, which are worked tutorials on various subjects.
  • robert 21
    Hello Andrew, i am  using already installed cadence virtuoso on our server,
    How can i find the SPECTREinstDir, the directory where SPECTRE was installed from the cadence startup window or something related to it?(so i can start learning this new tool with the manuals you pointed to)
    Two ways. One is to look in the spectre log file that appears when you run a simulation. You'll see something like this:
    Command line:
    /export/home/apps/SPECTRE181_isr/tools.lnx86/bin/spectre -64 \
    input.scs +escchars +log ../psf/spectre.out -format psfxl -raw \
    ../psf -I/export/home/myuser/demos/OCEAN/Models +lqtimeout 900 \
    -maxw 5 -maxn 5 -env ade -ahdllibdir \
    The installation path will be the bit before the tools.lnx86 directory highlighted above.
    Alternatively, in a terminal window, type:
    spectre_root
    which should tell you the same information.
  • robert 21
    Hello Andrew, thank you very much :-), the real time tuning is WOW.
