  2. RF Design
  3. bbspice fitting process taking too much time
  • Replies 7
  • Subscribers 63
  • Views 22631
anhchu88
anhchu88 over 5 years ago
I have an S parameter file generated by EMX for my oscillator. It has 56 ports and was simulated from DC-900GHz with a 1GHz step. When I used bbspice as the interpolation method for the nport, the rational fitting takes almost 1 day and still has not finished. Could you suggest some techniques I could use to reduce the fitting time? Here I have kept the nport compression as default. I'm curious since Tawna mentioned in an earlier thread that she used to simulate an n-port with 405 ports (https://community.cadence.com/cadence_technology_forums/f/rf-design/37979/how-to-compare-what-spectre-interprets-from-the-raw-s-parameter-file/1352837#1352837).
I'm using Spectre Version 16.1.0.510.isr10 64bit -- 13 Oct 2017, Virtuoso IC6.1.7-64b.500.15, EMX 5.12, interface date 15/7/2020.
I include here the settings for my nport, and the screenshot from transient simulation showing the iterations of the fitting process.
Many thanks and regards,
Anh
    Anh,
    I would suggest the following:
    1. Read the latest version of Tawna's 7 Habits of Highly Successful S-Parameters (Spectre 20.1, 19.1 and IC6.1.8 ISR9) guide
    2. Use SPECTRE20.1 not SPECTRE16.1 - there have been numerous improvements to the simulator and to bbspice (particularly in the latest versions) - so I'd strongly encourage you to check that
    3. This is covered in Tawna's guide, but  checking how smooth your s-parameters would be a good idea; a 1GHz step is pretty large...
    4. Contact customer support - this will be much easier to analyse and help with if we can actually see your data.
  • Tawna
    Tawna over 5 years ago
    Hi Anh,
    As a follow on to Andrew (I agree with everything  he said), update your Virtuoso version to IC6.1.8 ISR9/ICADVM18.1ISR9 or later.  We've made improvements to the nport in ISR9.  We have even more nport enhancements scheduled for ISR16 due out next month!  (I won't divulge anything...no spoilers.  :-)   )
    best regards,
    Tawna
  • anhchu88
    Thank you Andrew and Tawna for your suggestions. We are migrating to Spectre 20.1 and let's see if my problem could be solved.
    Best,
    Anh
  • anhchu88
    Dear Andrew and Tawna,
    We have just migrated to Spectre 19.1.0.541.isr14 64bit, IC6.1.8-64b.500.14, EMX 6.0 with Interface 6.0.0.  For Spectre 20.1, we are still requesting a license to use.
    I have re-simulated my layout structure from DC-900GHz with this time a 100MHz step. The data looks smooth to me in ViVA (I could show the screenshot if you are interested in it). To my surprise, the data is non-passive as there are peaks at around 755GHz where the magnitudes are greater than 1. You could see that clearly also in the impedance graph. That is why in transient simulation, the bbspice method produces large fitting error and Spectre instead uses the linear interpolation method (I have here set nportbbsversion=2). This leads to a  "blow-up" transient behavior in my circuit, in which the node voltage reaches 100kV level.
    I will contact customer support as soon as possible. In the meantime, I want to ask if you have some general recommendations about why EMX could generate nonpassive data, and how one should do to avoid it.
    Anh
  • anhchu88
    For your more information, I attach the settings in EMX as below.
    I used additional commands for emx: --double-precision --ans=1e-4 --print-double --solve-for-s --uniform-sources
    BR Anh
  • Tawna
    Tawna over 5 years ago in reply to anhchu88
    Hi Anh,
    Please file a Case at https://support.cadence.com .  When you file the Case, let me know the Case number.
    I'm thinking out loud here ....
    For generating an s-parameter file that will work with Spectre, see this appNote:  7 Habits of Highly Successful S-Parameters (Spectre 20.1, 19.1 and IC6.1.8 ISR9) .
    • You have a dc data point in EMX - this is good.
    • I plot the s-parameters on the Smith Chart using ViVA:  How do you plot S-Parameter data directly from ViVA? .  I see that you've done this - great!
    • Make sure your data is spaced closely enough to accurately capture the DUT behavior.   If the data looks disjointed or choppy/piecewise-linear, then there probably aren't enough data points - Your data looks pretty smooth on the Smith Chart, at least for s-parameter S59,27.
    • You can use the s-parameter validation tool in ADE Explorer to check for passivity, as outlined in:   S-Parameter Comparison Tool Aids in Troubleshooting.   I expect s-parameter data from EMX to be passive for a truly passive DUT.
    I can see your concerns regarding passivity by looking at your Smith Chart plot.   Is the DUT truly passive? (DUT=device under test)
    You *cannot* use bbspice interpolation when simulating an active device.  You must use linear interpolation.
    There are a number of parts to check:
    1. Is the DUT as designed truly passive?   And what are you modeling with the s-parameter data (what is the DUT)?
    2. Is the EMX setup correct?
    3. Is the resulting s-parameter data of good quality?
    4. Is the spectre setup correct?
    5. When you run your spectre simulation, are you getting any warnings or errors (I'm sure the answer is "yes")?   The spectre.out logfile will give excellent troubleshooting information that we'll need to know.
    best regards,
    Tawna
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to anhchu88
    If EMX produces non-passive S-parameter data, this is probably a bug that you should report to https://support.cadence.com. As a quick fix, especially if your circuit does not really work at these extremely high frequencies, you could try to simply remove all the data above 700 GHz or so from the S-parameter data file.
