  2. RF Design
  3. Transformer Model Using EMX
  • Subscribers 63
  • Views 14775
Ali Nikoofard
Ali Nikoofard over 4 years ago
On n-port extraction of passives (in this case a transformer), I observe that pin selection (internal or edge) has effect on L and Q. My question is, which one is correct (closer to Silicon)?
Also, on EMX form, advanced options, when should we ever select the "Radiation" box?
Thanks!
  • Tawna
    Tawna over 4 years ago
    There are two Articles on Cadence Online Support that'll help you on these questions:
     How and when to turn on full-wave mode in EMX
    EMX by default uses quasi-static mode.  If you have a testcase that falls into a class of structures where the size and highest frequency are not valid for quasi-static mode, then you must use full-wave mode.   Select the radiation checkbox to turn on full-wave mode.  Important:  you MUST use referenced port syntax for this to work properly.  See the Article for details.
    With regards to pin selection (internal vs edge) and general best practices, see:
    Tips on Specifying Ports in EMX
    and
    Using 'Cadence pins' as ports with access direction in EMX simulations
    Finally, I recommend this Article - a collection of "best practices" and helpful links:
    EMX "Quick Start" articles for new users
    best regards,
    Tawna
  • Ali Nikoofard
    Ali Nikoofard over 4 years ago in reply to Tawna
    Tawna,
    Appreciate the prompt reply, the contents were very helpful.
  • Tawna
    Tawna over 4 years ago in reply to Ali Nikoofard
    Happy to assist!
