  2. RF Design
  3. Frequency multiplier phase noise simulation and how to get...
  • Subscribers 63
  • Views 6299
Frequency multiplier phase noise simulation and how to get raising/falling edge phase noise contributions separately
maaz2020
maaz2020 over 3 years ago
I have a frequency multiplier driven circuit (x2) and would like to plot the phase noise for one edge only (as if I used sampled jitter). I have read the thread in
https://community.cadence.com/cadence_technology_forums/f/rf-design/27259/simulating-frequency-multiplier-phase-noise-in-pss-qpss-pnoise-qpnoise
in which it is concluded that the correct way for PSS + pnoise simulation is to use sweep=relative (rel-hr=2 in my case). This is available in noisetype=timeaverage, therefore cannot plot separately raising or falling edge phase noise.
I assume noisetype=sampled (jitter) is not the correct tool here, as it will ignore one rising and one falling edge of the output waveform in the PSS period.
So what is the correct way of getting separate raising/falling edges contributions?
    You could use sampled jitter and then plot the edgePhaseNoise - does that do what you want?
  • maaz2020
    maaz2020 over 3 years ago in reply to Andrew Beckett
    I don't think that's accurate as the jitter simulation takes one raising edge and falling edge only, respectively, and ignores the other two, so I get very low phase noise
  • Tawna
    Tawna over 3 years ago
    If you want to plot a freq multiplier and look at noise on an edge, you need to use sampled(jitter).  There is an article on https://support.cadence.com that walks you through the process.
    How to simulate a Multiplier in SpectreRF Shooting Newton PSS (24 Mar 2022)
    This article describes how to simulate a multiplier circuit under these three conditions:
    1. driven circuit with multiplier, using pnoise sampled
    2. oscillator circuit with multiplier, using pnoise sampled
    3. oscillator circuit with multiplier, using pnoise timeaverage
    If you want separate contributions from rising and falling edges, you can do a simulation looking at the rising edge and a second simulation looking at the falling edge (on the pnoise form, specify rising or falling).  You can set up separate pnoise jitter measurements.  Below I have one measuring the rising edge and another measuring the falling edge.
    e
  • maaz2020
    maaz2020 over 3 years ago in reply to Tawna
    Thanks Tawna..
    so I assume this procedure can be generalised to other multiplication factors by adding the correct  dB factor?
