  2. Verification IP
  3. Send SetAddress from VIP Host to VIP device via usb 2.0...
  • Subscribers 11
  • Views 10502
Send SetAddress from VIP Host to VIP device via usb 2.0 4-port hub (du
gulyaev
gulyaev over 7 years ago
Hi!
I am write test for usb hub using vip host and devices. I have a testbench with vip usb host, DUT(hub) and 4 vip usbdevices on each hub downstream port.
In test Hub is successfully enumerated by vip host, host enabling and reset hub port #1 which connected to vip device. After this I try to send SetAddress(2) from host to device via hub. Host is do not send packet to hub.
So, Hub is addressed and have address=1. Transactions to hub (Addr=1) sended successfully, but transactions to device is not sended by host.
.denalirc
HistoryDebug         On
HistoryFile          denali.his
TraceFile            denali.trc
ReportTimeUnits      ns
UsbBypassReset       0
UsbBypassTraining    0
UsbBypassInit        0
UsbBypassLmpInit     0
UsbAutoLmpInit       0
UsbAutoDeviceEnumeration        0
UsbAcceptSe0ForHSIdle 1
UsbSOFRightAfterReset 1
UsbAcceptJKForChirp   1
Finally test is hanging on infinitely waiting of transaction finishing:
    forever begin
      @ seqr.trEvent;
      item = tr;
      if (seqr.matchTr(item)) begin
        break;
      end
    end
  • gulyaev
    Problem is solved.
    It's need to polling hub port status and when port is in state 'enabled', host can send request to device.
    It doesn't worked if use only delay for resetting device.
