  2. Verification IP
  3. I have a question about UVM_INFO in my output log file
  • Subscribers 12
  • Views 17118
kkurenkov
kkurenkov over 6 years ago
It's seems strange UVM_INFO like that.
UVM_INFO [config_direct_seq.sv(55) (55) (81) (81) (55) (55) (55) (55) (81) (81) (55) (55) (81) ] { 35596.0ns } [mem_sys_st_config_direct_seq_1] [mem_sys_st_config_direct_seq_1] 'mem_sys_st_config_direct_seq_1' is completed
UVM_INFO [config_direct_seq.sv(55) (55) (81) (81) (55) (55) (55) (55) (81) (81) (55) (55) (81) (55) ] { 35596.0ns } [mem_sys_st_config_direct_seq_1] [mem_sys_st_config_direct_seq_1] 'mem_sys_st_config_direct_seq_1' is started
ld end in hvt_mem_sys_tb_top.dut.multi_rw_unit_inst.adm_control[0] at  49666.9ns
UVM_INFO [ys_item_transform.sv(638) (638) (355) (355) (348) (348) (348) (638) (638) (355) (355) (348) (348) (355) (348) ] { 50536.0ns } [xi4_to_memsys_item_transform_0] [UPD] hvt_mem_sys_ld_config_desc is updated
UVM_INFO [config_direct_seq.sv(54) (54) (80) (80) (54) (54) (80) (54) (54) (54) (80) (80) (54) (54) (80) ] { 50536.0ns } [mem_sys_ld_config_direct_seq_0] [mem_sys_ld_config_direct_seq_0] 'mem_sys_ld_config_direct_seq_0' is completed
UVM_INFO [config_direct_seq.sv(54) (54) (80) (80) (54) (54) (80) (54) (54) (54) (80) (80) (54) (54) (80) (54) ] { 50536.0ns } [mem_sys_ld_config_direct_seq_0] [mem_sys_ld_config_direct_seq_0] 'mem_sys_ld_config_direct_seq_0' is started
st end in hvt_mem_sys_tb_top.dut.multi_rw_unit_inst.adm_control[1] at  57652.5ns
UVM_INFO [ys_item_transform.sv(638) (638) (355) (355) (348) (348) (348) (638) (638) (355) (355) (348) (348) (355) (348) (355) ] { 58425.0ns } [xi4_to_memsys_item_transform_1] [CONFIG STORE] [STORE] in uvm_test_top.env.mem_sys_axi4_to_memsys_item_transform_1
UVM_INFO [config_direct_seq.sv(55) (55) (81) (81) (55) (55) (55) (55) (81) (81) (55) (55) (81) (55) (81) ] { 58425.0ns } [mem_sys_st_config_direct_seq_1] [mem_sys_st_config_direct_seq_1] 'mem_sys_st_config_direct_seq_1' is completed
I use AXI VIP and XCELIUM1909
Do you know how to fix this bug?
  • kkurenkov
    I found error. problem was in report server.  It was my fault.
