  2. Verification IP
  3. xmvhdl_p: *F,DLUNNE: Can't find STANDARD at /tools/cadence...
  • Subscribers 13
  • Views 8226
xmvhdl_p: *F,DLUNNE: Can't find STANDARD at /tools/cadence/installs/XCELIUM1803/tools/inca/files/STD. error while compiling a VHD file
Sarath Krishnan
Sarath Krishnan over 6 years ago
Hi Team,
               I am getting the following error while executing a vhd file using XCELIUM1803. Could you please help me to resolve it ?
srcs/sample.vhd:
xrun: *E,VHLERR: Error during parsing VHDL file (status 2), exiting.
Sarath
  • StephenH
    StephenH over 6 years ago
    You posted this in the wrong forum, which is probably why nobody responded.
    The error you've seen is most likely caused by failing to "configure" the Xcelium installation after downloading it. I would recommend that you login to the support portal (https://support.cadence.com/) and file a ticket so that one of the hotline team can work directly with you to resolve issues like this.
