  2. Verification IP
  3. Simvision debugging techniques
  • Subscribers 12
  • Views 15005
MaheshKumar
MaheshKumar over 6 years ago
Hi All,
I am using simvision(64) 19.03.a001 version.
I would like to more about debugging in simvision.
1) .svcf (data base saving)
Lets say I ran one testcase and saved the Database as TEST1.svcf, which is a passing scenarios.
I ran one more testcase which is TEST2, which is generally failing scenario. I will load this into simvision along with TEST1.svcf.
Now in the waveform,  I have two databaes, one is passing one and one more is failing one.
With this feature, will any difference shown by simvision to identify which signal has caused the fail or where is the exact issue by comparing.
a) I just want to understand using .svcf can we compare data base of pass and fail so that easily we can point out the exact issue ?
b) Lets say we have 100 scenarios and it is difficult to have 100 .svcf's always. So, how can be this used in general way to that it can be re checked for 100 scenarios ?
Kindly advice for both a and b
2) .svwf (saving signals)
Hope this is just saving set of signals and it is independent of particular database. This we can use with any database. Please confirm
Thank You,
Mahesh
