  2. Verification IP
  3. Can't drive the Slave Active AXI Stream Tready signal
  • Subscribers 12
  • Views 3240
TomasPrudente
TomasPrudente over 3 years ago
In order to test one specific feature of my DUT I need to take control of the Tready signal of my AXI Stream active slave VIP.
Reading the documentation: Stream VIP Reference for UVM SystemVerilog (stream_sv-uvm_reference.pdf)
I found out this register to take control of the Tready called DENALI_STREAM_REG_driveTready:
I am already using another register to configure the VIP called DENALI_STREAM_REG_EnableTracker to take control of the verbosity of the VIP messages, and it's working as expected:
But when I try to configure the DENALI_STREAM_REG_driveTready I have the error: 'DENALI_STREAM_REG_driveTready': undeclared identifier [12.5(IEEE)].
This is how I'm using (or trying to use) the register configuration within my run_phase():
m_axis_egress_active_slave_agent.regInst.writeReg(DENALI_STREAM_REG_EnableTracker, 0); <-- This is working fine
m_axis_egress_active_slave_agent.regInst.writeReg(DENALI_STREAM_REG_driveTready, 2'b10); <-- This is not compiling at all because it doesn't find the DENALI_STREAM_REG_driveTready
Any suggestion will be really appreciated, thanks.
Tomás Prudente
