  2. Verification IP
  3. VoltusFi temperature settings
  • Subscribers 12
  • Views 5747
dakuang01
dakuang01 over 3 years ago
I ran two same EMIR jobs with transient simulation at different temperatures 27C and 105C. However, 105C one shows less current values for all pwr/gnd than 27C for some reason, which is reversed.
I checked the temp was setting correctly for each runs in the log files but tnom was the same as 27C
Is there anything else I need to check in the setup that might have affected to the current values?
Jane
