  2. Verification IP
  3. How to implement a basic clean read-write sequence in Specman...
  • Subscribers 12
  • Views 1918
How to implement a basic clean read-write sequence in Specman? Is this approach correct?
AP202508036621
AP202508036621 over 1 year ago
Hi, I’m trying to write a simple read-write sequence in Specman using a BFM. I wrote the code below, but I’m unsure if it’s the correct and clean way to do it. I see many variations online, which confuses me.
The sequence grabs the driver, performs a write transaction, waits a random number of clocks, performs a read transaction at the same address, then releases the driver.
I don’t have access to Cadence tools to test this, so I would appreciate feedback on the correctness of the sequence, use of grab/ungrab, and any improvements or best practices you can suggest.
Also, how can I run or simulate this without a Cadence license?
Thanks in advance!
**Code:**
    // READ-WRITE Sequence
    struct my_item like any_sequence_item is {
        addr: byte;
        data: uint(bits:32);
        rd_wr: bit;
    type seq_type : enum { READ, WRITE };
    sequence my_seq using item: item = my_item, created_driver = my_bfm_u;
    extend my_seq {
        !sequence_type: seq_type;
    extend my_seq is {
        keep soft item.rd_wr == (sequence_type == WRITE) ? 1 : 0;
        clk is @my_driver.clk;
        body() @clk is {
            var rand_num: uint(bits:4);
            var last_addr: byte;
            for i from 0 to 10 {
                grab(my_driver);
                do WRITE my_seq keeping { last_addr == it.addr; };
                wait[rand_num] * clk;
                do READ my_seq keeping { it.addr == last_addr; };
                ungrab(my_driver);
                gen rand_num;
    unit my_bfm_u is {
        smp: smp_u;
        clk is @smp.clk;
        run() @clk is also {
            drive_read_write();
        drive_read_write() @clk is {
            item: my_item;
            while (TRUE) {
                item = my_seq.get_next_item();
                smp.addr = item.addr;
                smp.rd_wr = item.rd_wr;
                smp.data = item.data;
                emit my_seq.item_done;
    unit my_agent_u is {
        smp: smp_u is instance;
        bfm: my_bfm_u is instance;
        keep bfm.smp == smp;
        monitor: monitor_u is instance;
        keep monitor.smp == smp;
