  2. OrCAD X Presto PCB
  3. Orcad X Presto 23.1 : Save default settings of the inte...
  • State Verified Answer
  • Subscribers 17
  • Views 2328
Orcad X Presto 23.1 : Save default settings of the interface
SamTronic
SamTronic over 2 years ago
When I start OrCAD X Presto, I always need to turn ON the grid display. Also, when I start a new PCB or footprint, I need to change the units from mils to mm.
I did not find in the different menus the way to save the default configuration of my interface.
Is there a config file to edit or an option on the interface to do that ?
  • vidhyaparameswari
    vidhyaparameswari over 2 years ago +3 verified
    As tested in Orcad X Presto, the grid settings, color settings are getting reset to default ones, eventhough the board file has been saved with the user settings. RnD has been notified about the same and…
  • SamTronic
    0 SamTronic over 2 years ago
    Also, saving the default colors of the layers.
  • vidhyaparameswari
    0 vidhyaparameswari over 2 years ago
    As tested in Orcad X Presto, the grid settings, color settings are getting reset to default ones, eventhough the board file has been saved with the user settings. RnD has been notified about the same and  a CCR has been in Place for the issue.
    • Vote Up +3 Vote Down
