  2. OrCAD X Presto PCB
  3. It should not take hours to figure out how to rotate text...
  • State Verified Answer
  • Replies 11
  • Subscribers 16
  • Views 6088
It should not take hours to figure out how to rotate text 45 degrees :(
DG202504226528
DG202504226528 over 1 year ago
Even chatgtp can't figure it out.  I can't even do it in the legacy tool.  Why is everything stuck at 90???? Another super simple thing that would be solved in two seconds in any other tool.
  • DG202504226528
    DG202504226528 over 1 year ago in reply to DG202504226528 +2
    from chat Yep, that’s exactly the “old Allegro way” of getting around Cadence’s 90° lock: Open in the Legacy (Allegro-based) editor , not Presto. Use the General Edit filter to make sure…
  • DG202504226528
    DG202504226528 over 1 year ago +1
    So for anyone that can't rotate at anything else than 90... close Presto, open legacy tool, click general edit, click text in the filter, click on said text, right click for move, right click option, click…
  • JuanCR
    JuanCR 6 months ago in reply to DG202504226528 +1 verified
    Hi DG202504226528 You can find the option in the Properties Panel under the "Location" section:
  • DG202504226528
    0 DG202504226528 6 months ago in reply to JuanCR
    Yeah, that works on a couple of things like a part that's placed, but not on a trace segment and random other things.  Not like the Legacy tool that you can rotate anything.
    Thanks everyone :)  Just another cranky morning for me ;)  I think what's really frustrating is that ChatGPT keeps on sending me into rabbit holes with Allegro features that are not in Orcad since they're basically the same tool.
  • JuanCR
    0 JuanCR 6 months ago in reply to DG202504226528
    True. This will only work on components. About ChatGPT, just be careful with the AI hallucinations. I'd recommend you use the support.cadence.com portal instead. It has an AI agent integrated.
  • DG202504226528
    Thanks JuanCR.  I'll def try that next time :)
  • Zhifeng Jin
    0 Zhifeng Jin 3 months ago in reply to JuanCR
    I’m confused about why you’re able to upload images successfully.
    But every time I try uploading on my end, it keeps prompting: An error occurred. Please try again or contact your administrator.
  • Zhifeng Jin
