  2. OrCAD X Presto PCB
  3. LiveDoc Document randomly disappear when switch license
  • State Suggested Answer
  • Answers 1
  • Subscribers 16
  • Views 1785
Kevcsc
Kevcsc 11 months ago
Hello, I am currently using OrCAD X Presto 24.1. For LiveDoc, I created a custom template for the fabrication and assembly files, which requires a Professional License to apply. Although I successfully generated a LiveDoc document using the Professional License, I noticed that when I switch to a Standard License, the LiveDoc document is sometimes deleted unexpectedly. This has happened multiple times, and I’m wondering if this is a known issue and is there a fix for it.
  • techiecs
    techiecs 11 months ago +1 suggested
    I tested this same behavior at my end in SPB24.1 OrCAD X PCB Presto Professional first by creating a template, saving it a name. The I reopened Presto using OrCAD X PCB Presto Standard license and the…
  • techiecs
    0 techiecs 11 months ago
    The I reopened Presto using OrCAD X PCB Presto Standard license and the same board file in which created a template earlier. Now when I open this board, I see all the template settings saved there and I could open it without a need to create a new Template.
    Can you please confirm which hotfix of the tool you see this issue in just to confirm.
  • Kevcsc
    0 Kevcsc 11 months ago in reply to techiecs
    Hi, thank you for the reply. Currently im using version 24.1 S007 (4362613) [10/21/2025]. Please let me know if this is what you are looking for.
    As I mentioned earlier, the LiveDoc usually remains intact when I switch between licenses. However, I have definitely observed instances where it randomly disappeared before.
