  2. Allegro X APD
  3. Importing vias in Allegro APD
  • Subscribers 69
  • Views 18516
Siraj Akhtar
Siraj Akhtar over 16 years ago
I want to know how to import via’s into Allegro APD.
 I have a file that contains the coordinates of my package vias. I want to import them into APD so that I don’t have to manually replace each via. I have a VIA_175 padstack already created that I want to use for these vias. How can I import this into APD?
Alternatively, I have tried importing a gds that contains the vias. I can bring this into APD as a conductor or as a shape, but I can’t figure out how to replace these so that they are now VIA’s using the VIA_175 padstack.
Any thoughts?
  • BillAcito
    BillAcito over 16 years ago
    Are you saying that you have a file with the coordinates for a BGA footprint?
    Use Add-->BGA-->BGA Text in Wizard.
    You can specify the VIA_175 as part of that process.
  • Siraj Akhtar
    Bill,
    Thank you for the response.
    I use the following BGA in file:
    _____________
    file: /Allegro/BGA_mychip.txt
    Date: Wed May  5 16:17:01 2010
    Units: microns, 2 decimal places
    RefDes: BGA
    Origin: (0.00 0.00)
    Rotation: 0.000
    Pad Layer: BOT_COND
    Extents: ((-4500.00 -4500.00) (4500.00 4500.00))
    Pin Number       Padstack          X Coord Y Coord            Rotation            Pin Use Net Name
    A2        BGA_PAD_1     -4000    -3500    0          BI         VSS_OSC
    A3        BGA_PAD_1     -4000    -3000    0          BI         VDD_OSC
    _______________
    So now, if I have the via center points, can I do the following:
    file: /Allegro/VIA_mychip.txt
    RefDes: BGA
    Origin: (0.00 0.00)
    Rotation: 0.000
    Pad Layer: ???
    V1                    VIA_175            -1940.41            -2010.79            0          BI         VSS_OSC
    V2                    VIA_175            -3048.22            -3183.66            0          BI         VDD_OSC
    _______________
    What do I specify for Pad Layer in the header? TOP_COND, BOT_COND?
    Also when this VIA comes in, will it have the connectivity because it already has the Net Name assigned to it?
    Regards.
    --Siraj.
  • mikem
    mikem over 16 years ago
    This can be done by using a script:
    1.  Open the text file that contains your via coordinates.  Insert the word "pick" and a space, before each coordinate.  Example: pick 2.350 4.560. This may be easiest to do, in Microsoft Excel.
    2.  In your design, Place via_150, in an unused area.
    3.  Using FILE>SCRIPT, create a new script.  Give the script a name and select RECORD.  Within your drawing, copy the via that was placed earlier, using the center of the via as the copy origin.  Place a copy of the via, by entering an absolute coordinate on the command line, i.e. x 2.5 y  3.7.  Stop the sript and open the resulting sript file, in a text editor.
    4.  When you open the script file in a text editor, you will find an entry for the via that was copied.  It will read something like:  pick 2.5 3.7.  Remove this entry and insert all your via coordinates from your text file in STEP 1, here.  Do not copy over any other entries in the scipt.  Save the file.
    Go back to your design and replay the script.  The command line will prompt you for a copy origin.  Using your mouse, pick the via that was placed in STEP 2.  After selecting this via, the script will place copies of via_150 at all the proper coordinates.
