  2. Allegro X APD
  3. multiple bonding points
  • Subscribers 68
  • Views 16664
VLSI88
VLSI88 over 14 years ago
 I have a die pad with multiple bonding wires come out from it. Is there a way to create several bonding points on that die pad so the wires
will be seperated instead of coming out from the center. Please help. Thanks.
  • Tyler
    Tyler over 14 years ago
    In APD and SiP, you do not pre-define bonding points on the pads. Rather, you spread the wires per your manufacturing rules using the Route -> Wire Bond -> Tack Point Move command. You can choose to manually move wires a specified distance, move wire ends interactively, or have the tool automatically spread them evenly either parallel or perpendicular to the die edge.
    There is, I believe, even a DRC check for wire end to wire end clearance. It's in Constraint Manager, under the Assembly workbook, Wire folder, Wire-to-Wire Online Spacing page. The column name is "Wire End to Wire End".
    - Tyler
  • VLSI88
     Thank you Tyler, I can now move the wire that is there on the die pad, how can I add another wire to the same DP? Thanks again.
  • VLSI88
    Never mind the above question I found out how that was done.Thanks again Tyler.
  • Tyler
    Glad you got everything figured out so quickly. Good luck with your design.
