  2. Allegro X APD
  3. Can't open file after dbdoctor update from 14.x to 16.5
  • Subscribers 69
  • Views 5443
Doug Powell
Doug Powell over 13 years ago
I have to deal with older package designs from 14.x days that we used to do as .brd files.  I have used dbdoctor (dbdoctor_ui.exe) to update one of the files to 16.5, and tried to use the BRD import option to bring it into APD (16.5).  File failed to load with the error message: "ERROR(SPMHUT-43): File selected is not of type Layout."  I get the same error when trying to open in Allegro PCB Designer (16.5) or Allegro Physical Viewer (16.5).  Any ideas what the problem might be?  Any workarounds other than finding an old set of install files for 14.x?
  • Jeff Gallagher
    Jeff Gallagher over 13 years ago
    The update should work.  If you can get on to Cadence Online Support (COS), create a new Case and send in the 14.x database they can try to update it and find the problem.  14.x SW is no longer supported but the database's created by older SW are still supported.
  • Doug Powell
    Found a simple solution to the problem.  Turns out that renaming from a .BRD extension to a .MCM extension allowed the up rev'ed file to load successfully.  The original ver 14.x file is a .BRD.  Up revving with DBDOCTOR was apparently successful, but the new .BRD file would not open in APD, Allegro PCB Designer, or Allegro Physical Viewer.  After the rename (and nothing else) APD loads the file successfully.  Curious.
