  2. Allegro X APD
  3. Can't create plating bar in SIP
  • Subscribers 68
  • Views 3190
VLSI88
VLSI88 over 13 years ago
 I was working with 16.5 SiP version and I couldnot create the plating bar. It kept giving me this message:
Symbol extents are greater than the drawing extents ... increase the drawing extents.
 I looked at the dwg extent it was set way more than it should be still did not work.
Please help.
Thanks so much
  • BillAcito
    BillAcito over 13 years ago
    What are your design units, and what distance away from the package edge are you entering in for the pbar?
    Bill
  • VLSI88
     I am using um for unit and the plating bar is only 200um away from the pkg edge.
    dwg extent is set at 500000.
    Thanks for your help
  • BillAcito
    If the BGA's component class is incorrect, or if it is missing some of the boundary subclasses (place bound, assembly, etc), you will get this error. You may want to work with your customer support person to figure out the specific issue.
     Bill
