  2. Allegro X APD
  3. Scripts or commands to create the package stackup
  • Replies 38
  • Subscribers 69
  • Views 46346
sidm
sidm over 6 years ago
Hi All,
are there any commands or scripts that can help to create package stack-up from scratch in an automated manner.
Something that can take in no. of conductor , dielectrics layers along with the thickness and material information and dump a tech file or mcm to be imported into SIP ?
I also wish to parametrize the package dimensions.
regards
  • sidm
    sidm over 6 years ago in reply to sidm
    thanks for the reply. The news vias that i created are visible in the via list inside CM but not when I am trying to add them  during routing.
    Also seems there has been some issue as I am getting the below message when opening the design "
    (SPMHA1-161): Cannot open the design because of database problems. Run the dbdoctor command on the design and try to open again.
  • masamasa
    masamasa over 6 years ago in reply to sidm
    did u assign the padstack that can be used from which layer to which layer?
    if not, u need to assign it on the constraint manager.
  • sidm
    sidm over 6 years ago in reply to masamasa
    thanks for the reply. I see them in the CM in the via list,
    do i need to define the TO & FROM anywhere else also ?
  • masamasa
    yes, you need to define which layer to which layer the padstack can be used.
  • sidm
    yes I did define assign which layer to which layer  in the padstack editor and that can be seen in the CM vias list as well (START END) , where else do i need to define it and how ?
