  2. Allegro X APD
  3. Scripts or commands to create the package stackup
  • Replies 38
  • Subscribers 69
  • Views 46352
sidm
sidm over 6 years ago
Hi All,
are there any commands or scripts that can help to create package stack-up from scratch in an automated manner.
Something that can take in no. of conductor , dielectrics layers along with the thickness and material information and dump a tech file or mcm to be imported into SIP ?
I also wish to parametrize the package dimensions.
regards
  • masamasa
    masamasa over 6 years ago in reply to sidm
    you can go to the padstack list on tools->padstack->modify desgin padstack
    open the padstack by double clicking the padstack on the list and make sure all the pad diameter and layer names are correct.
  • sidm
    sidm over 6 years ago in reply to masamasa
    yes but  don't see the new vias in the tools->padstack->modify desgin padstack, i see it only in the CM via list .
    Not sure what is the issue
  • masamasa
    can you find the path to the padstack directory is correct by typing set in the command line?
    you can see the path on padpath.
    you need to make sure that the new padstack is located at the directory.
  • sidm
    Yes the new padstack is in the directory where the design is.
    Can you please let me know what does QMS stand for in the CM , there are 2 rows one is DEFAULT & the other is QMS under the VIA column in physical constraints.
  • masamasa
    i somtimes see qms on the designs from my customer.
    but i have never used it on my design  personally as i do not know what it is.
    maybe your osat people put it into the osat database file.
    you can create a new padstack from tools->padstack->modify desgin padstack by doing "save as."
