  2. Allegro X APD
  3. Does anyone know how to connect two pins of a die to the...
  • Replies 7
  • Subscribers 70
  • Views 11245
Does anyone know how to connect two pins of a die to the same net so they are considered a short inside of APD?
JS532
JS532 over 3 years ago
I'm trying to create a specific use case that has a die component with both topside and backside connections. The catch is that these connections need to be considered an electrical short. When I assign them to the same net they need to be connected outside of the die. I'm hoping there's a way to consider these two pins to be an electrical short. I haven't yet figured this out. I did find a PACK_SHORT property possibility inside of a schematic tool but there doesn't seem to be a way utilize this this in APD?
Any help is greatly appreciated.
Joe
  • masamasa
    0 masamasa over 3 years ago
    what i usually do is to add one more layer (a conductive layer and a dielectric layer as a pair) on top of the existing design. on the added layer with clines and vias, u can connect the two pins
  • JS532
    0 JS532 over 3 years ago in reply to masamasa
    Hi masamasa,
    I have done this in the past but it won't work for this situation. I need connections on the top and bottom of the die to be considered a short. The bottom side is attached to an embedded substrate layer and the top side is in a diestack. I thought a d2d via might work but it won't allow this to an embedded layer, only a surface layer. I'm still stuck.
  • masamasa
    0 masamasa over 3 years ago in reply to JS532
    r u talking about an embedded die like an embedded bridge?
  • JS532
    Yes, this is an embedded die. You could consider it to be similar to an embedded bridge.
  • masamasa
    what i see on our customers' design with embedded bridge is that they treat the embedded bridges as part of their package (interposer). they do not treat the embedded bridges as components (symbols). if u r talking about embedded dies, that may not be possible as embedded dies can be more complex than embedded bridges.
