  2. Allegro X APD
  3. Add footprint
  • State Verified Answer
  • Answers 1
  • Subscribers 70
  • Views 5226
Add footprint
bdc66a938f164d
bdc66a938f164d over 1 year ago
I have a footprint for a component defined in `/path/to/footprint.dra`. How can I include it as an element of my `package.mcm`? I am trying to do [this]( BoardSurfers: Training Insights: Manually Placing Components in Allegro PCB Editor) but I see no way of browsing for `/path/to/footprint.dra`.
  • DavidJHutchins
    DavidJHutchins over 1 year ago +1 suggested
    Use the following steps: start Setup->User Preferences... Pick Paths>Library Then pick the value box for psmpath Then in the 'psmpath Items' window pick the + icon to add a new entry, pick it's…
  • bdc66a938f164d
    bdc66a938f164d over 1 year ago +1 verified
    The way of doing this is: 1. Make sure that when you save `footprint.dra` Allegro also creates `footprint.psm` in the same folder, this should happen automatically. 2. Make sure that `/path/to` is in…
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    Pick Paths>Library
    Then in the 'psmpath Items' window pick the + icon to add a new entry, pick it's ... to navigate to your 'path/to' folder, then pick 'Choose'
    then pick 'OK' to close the 'psmpath Items' window
    Then pick 'OK' at the bottom of the 'user preferences editor' window
  • bdc66a938f164d
    +1 bdc66a938f164d over 1 year ago
    2. Make sure that `/path/to` is in the `Setup/User preferences/Paths/Library/psmpath` list.
    3. Go to `Logic/Edit parts list...`, click on `Physical packages` and search for `footprint`. It should show up there. Complete the other fields in the "Parts list" window and click on `Add`. Your new component should show up in the list. Now close this with the `Ok` button.
    4. Go to `Place/Manually...` and now under "Components by refdes" you should find your component ready to be placed.
