  2. Allegro X Capture CIS
  3. Grid spacing in schematic part editor
  • Subscribers 51
  • Views 28592
chadga
chadga over 8 years ago
I am trying to create a part in OrCAD Capture 17.2, i want to change the grid spacing of the schematic part editor page. I tried to change the grid spacing in "options>>preferences>>grids", it works only with the schematic page. But the part editor page grids remains unchanged. Is there any way i can change the grid spacing while i am creating a library part.
Kindly let me know if it can be done.
Chadga
  • excellon1
    excellon1 over 8 years ago +1
    Nope. It has a fixed grid spacing. In thinking about this it is probably because when you place a symbol on the schematic you would want it's pins to land on the grid so that they could be wired up. In…
  • excellon1
    0 excellon1 over 8 years ago
    In the schematic part editor there is a snap to grid option on the tool bar. This is useful if you need to move things like pin numbers and pin names around as you
    are creating symbols.
    Paul
  • chadga
    0 chadga over 8 years ago in reply to excellon1
    Thank you for the quick reply Paul. Now I understood why it isn't allowed
    Regards
    Chadga
  • KADcad
    0 KADcad over 5 years ago in reply to chadga
    Suggested feature: Continue limiting pin placement to the large grid size, but allow lines, circles, etc to use a finer grid.  I'm trying to make an RNET that looks right, but is small enough to mesh with busses on the schematic page.
  • redwire
    0 redwire over 5 years ago in reply to KADcad
    Just place the pins on grid then turn the grids off for fine detail like you want.  You don't have to use grids for graphic objects
