  2. Allegro X Capture CIS
  3. How To Change Library Path In OrCAD Capture 17.4
  • Replies 16
  • Subscribers 52
  • Views 73954
Bruce Sun
Bruce Sun over 6 years ago
I downloaded the symbol and footprint of a part from Ultra Librarian to a local folder. After I put the part in the schematic there is a warning as below.
WARNING(ORCAP-2434): Footprint 'CP_32_15' specified in PCB Footprint for instance 'U1' is missing. Ensure 'CP_32_15' is in the library path.
Does anyone know if there is a way to add my local folder to the library search path? I want to keep the default library folder clean and use project specific folder for symbols and footprints.
Thanks.
Bruce
  • RFinley
    RFinley over 6 years ago in reply to Bruce Sun +3
    [Allegro Footprints] only previews your footprints when you select a part. Needs to be under [Part Library Directories]
  • RFinley
    RFinley over 6 years ago +1
    First, you need to figure out where your SPB_Data folder is as that will have the Capture.ini config file you need to edit. Easiest way is to open a windows file browser, click on the URL bar at the…
  • Bruce Sun
    Bruce Sun over 6 years ago in reply to RFinley +1
    Thanks for your information. When I start the Capture CIS it shows the following line INI File Location:C:\SPB_Data\cdssetup\OrCAD_Capture/17.4.0/Capture.ini So I changed the file as below. [Allegro…
  • RFinley
    0 RFinley over 6 years ago
    Easiest way is to open a windows file browser, click on the URL bar at the top and type %home%
    From this directory, navigate to cdssetup\OrCAD_Capture\ then whatever version you are using.  In the version directory, you need to add or change the capture.ini file.
    Search for a line with:  [Part Library Directories]    If it isn't there, you need to add it before any other line having bracket characters.  The format is [parameter name] then parameter.  Insert after a line that doesn't have bracket characters on both ends.
    Immediately after that line, you list the directories having the *.olb library files in them.
    My setup has:  Dir0=C:\svn\Hardware\Libraries\orcad
    Restart  Orcad.
    Each time Orcad is opened, you should have a scrolling window at the bottom of the screen that has a text line starting with:  INI File Location:  C:\whatever your home directory path is\Orcad_Capture\<version>\Capture.ini
  • Bruce Sun
    0 Bruce Sun over 6 years ago in reply to RFinley
    Dir0=C:\Cadence\SPB_17.4\share\pcb\pcb_lib\symbols
    Dir1=C:\Users\brucesu\Documents\OrCAD\Projects\Lib
    But is doesn't work. I still saw the same warning message.
  • RFinley
    0 RFinley over 6 years ago in reply to Bruce Sun
    Needs to be under
    • Vote Up +3 Vote Down
  • steve
    0 steve over 6 years ago
    So these DRC's are driven by the board file. Make sure your psmpath and padpath are defined in PCB Editor. If you don't have a board file you will see these DRC's until you run Design Sync then once the footprints are found the DRC check is re-run.
  • RFinley
    0 RFinley over 6 years ago in reply to steve
    Ugh.  When I see "Orcad Capture" in the subject, I think schematic.  Not layout.  Thanks Steve.  Apologies to Bruce.
