  2. Allegro X Capture CIS
  3. How To Change Library Path In OrCAD Capture 17.4
  • Replies 16
  • Subscribers 52
  • Views 73956
Bruce Sun
Bruce Sun over 6 years ago
I downloaded the symbol and footprint of a part from Ultra Librarian to a local folder. After I put the part in the schematic there is a warning as below.
WARNING(ORCAP-2434): Footprint 'CP_32_15' specified in PCB Footprint for instance 'U1' is missing. Ensure 'CP_32_15' is in the library path.
Does anyone know if there is a way to add my local folder to the library search path? I want to keep the default library folder clean and use project specific folder for symbols and footprints.
Thanks.
Bruce
  • RFinley
    RFinley over 6 years ago in reply to Bruce Sun +3
    [Allegro Footprints] only previews your footprints when you select a part. Needs to be under [Part Library Directories]
  • RFinley
    RFinley over 6 years ago +1
    First, you need to figure out where your SPB_Data folder is as that will have the Capture.ini config file you need to edit. Easiest way is to open a windows file browser, click on the URL bar at the…
  • Bruce Sun
    Bruce Sun over 6 years ago in reply to RFinley +1
    Thanks for your information. When I start the Capture CIS it shows the following line INI File Location:C:\SPB_Data\cdssetup\OrCAD_Capture/17.4.0/Capture.ini So I changed the file as below. [Allegro…
  • RFinley
    0 RFinley over 6 years ago
    https://www.youtube.com/watch?v=4Z3IOKjaqzo
    (sorry about that)
  • JTKcommunicat
    0 JTKcommunicat over 6 years ago in reply to RFinley
    I thought this would help me, but it did not.
    I start Orcad Capture and all looks good.
    Then I click the recent file (schematic) that I am developing and I get the same "error" as the original poster.
    However, I can see the footprint for every part in my schematic.   So why does it give me an error?
    I tried adding, as explained above)
    Dir0=C:\Cadence\SPB_17.4\tools\capture\library
    That made no difference at all.   And I do not understand how it possibly could.    I know I was in the correct .ini file, because to test that, I removed a few lines and it gave lots of new errors. (Then restored it with my backup .ini)
    Orcad already knows where my library is.  Orcad is showing me footprints but then telling me they are not there.
    My schematic is complete.  I successfully imported a lot of footprints and graphics from Digikey (either SnapEDA or Ultralibrarian).  I also got pretty good at editing the footprints because many I downloaded have pin errors.  Orcad is seeing my corrected footprints.  So Allegro seems to be working correctly, and Orcad seems to be working correctly.
    But I need to get from where I am to placing the parts on a board and start layout.
  • RFinley
    0 RFinley over 6 years ago in reply to JTKcommunicat
    Are you unable to place parts on a board or are you unable to place parts on a schematic page?
    If you are capturing a schematic, you need to make sure [Part Library Directories] points to your *.OLB files when placing CIS parts.
    [Allegro Footprints] only has a path for footprint preview when placing CIS parts.
  • JTKcommunicat
    My schematic is completed.
    I can preview the footprint of every part in Orcad.
    I have made some progress.... I can even "sync" when I make a small change to the schematic.   I changed a UA78L05 from surface mount to through hole and it did magically update Allegro.... so I have that much working.  And when I changed it back to surface mount footprint, it again worked flawlessly.
    Allegro lists all of the reference designators when I go to manually place part by "Components by refdes";  but about half of the parts do not show a footprint.   I look in the directory and the footprints are there... I manually search there is a .dra for every part, and I believe the padstacks are all there because they show in Orcad footprint preview.
    Example   D3 is a BZX84C30.   In orcad I can see the SOT-23-F-M footprint.   I try to manually place "components by refdes" ...   D3 is there in the list, but I don't see a preview and can not place the part.
    So I try to manually place "Package symbols" (after checking "Library" in "Advanced Settings.") and for example SOT-23-F-M is not there.   But look in the directory with windows "file explorer" and SOT-23F-M.dra is there.
  • RFinley
    Oh, well.  You need to set the library path (or verify it) in Allegro/Orcad the layout tool.
