  2. Allegro X Capture CIS
  3. How To Change Library Path In OrCAD Capture 17.4
  • Replies 16
  • Subscribers 52
  • Views 73962
Bruce Sun
Bruce Sun over 6 years ago
I downloaded the symbol and footprint of a part from Ultra Librarian to a local folder. After I put the part in the schematic there is a warning as below.
WARNING(ORCAP-2434): Footprint 'CP_32_15' specified in PCB Footprint for instance 'U1' is missing. Ensure 'CP_32_15' is in the library path.
Does anyone know if there is a way to add my local folder to the library search path? I want to keep the default library folder clean and use project specific folder for symbols and footprints.
Thanks.
Bruce
  • RFinley
    RFinley over 6 years ago in reply to Bruce Sun +3
    [Allegro Footprints] only previews your footprints when you select a part. Needs to be under [Part Library Directories]
  • RFinley
    RFinley over 6 years ago +1
    First, you need to figure out where your SPB_Data folder is as that will have the Capture.ini config file you need to edit. Easiest way is to open a windows file browser, click on the URL bar at the…
  • Bruce Sun
    Bruce Sun over 6 years ago in reply to RFinley +1
    Thanks for your information. When I start the Capture CIS it shows the following line INI File Location:C:\SPB_Data\cdssetup\OrCAD_Capture/17.4.0/Capture.ini So I changed the file as below. [Allegro…
  • JTKcommunicat
    0 JTKcommunicat over 6 years ago in reply to RFinley
    To test to see if I have the library path set correctly, I
    • removed a footprint from the directory.
    • Then restarted Allegro and the footprint was gone.
    • shut down Allegro
    • Return the part to the directory
    • Restart Allegro
    • I can place the part again.
  • JTKcommunicat
    0 JTKcommunicat over 6 years ago in reply to JTKcommunicat
    Discovered this !
    Looking for a long time in the symbols directory I have discovered that the parts that DO show up in Allegro have at least two different files ....   a    .dra    AND  a    .psm file.
    The parts that Allegro will not let me place have a  .dra file but do NOT have a  .psm file.
    Orcad seems to be happy with footprints that only have a .dra and no .psm file.  But Allegro apparently needs both.
    I can not find hardly anything in the user guide about .psm files.    Does anyone know where they come from?  How I can create them?
  • DavidJHutchins
    0 DavidJHutchins over 6 years ago in reply to JTKcommunicat
    The Allegro .dra files are the input drawings that are saved as compiled symbols during the save process,
    the system level 'create_sym' command can be used to create (compile) a symbol from a dra file.
    the 'package' drawing types are saved as .psm, the 'mechanical' drawing types are saved as .bsm, the 'shape' drawing types are saved as .ssm, etc...
  • JTKcommunicat
    0 JTKcommunicat over 6 years ago in reply to DavidJHutchins
    Thank you very much for the help.
    Now for anyone looking for the simple answer to this;  "footprints do not show up in Allegro even though they exist"     "Once you find the solution, the problem seems simple."
    My 'paths' and 'directories' and stuff were all good.   I do not know why a lot of parts did not have a .psm file.... but it is easy :-)
    1. In Orcad click on the part that you can not place in Allegro.  Click properties and write down the footprint that is assigned to the part that you can preview in Orcad.   e.g. LGA-16_3x2x1mm
    2. Go to your symbols directory with windows file explorer
    3. Find the   .dra  file with that footprint name ....   e.g.   LGA-16_3x2x1mm.dra
    4. double-click on that file   LGA-16_3x2x1mm.dra
    5. wait for Allegro to open up and do its thing.
    6. then go to top left click "file"
    7. click "create symbol"     It will make the .psm file that was missing
    8. go back to your board layout in Allegro and "place manual" again and now the part will show up :-)
    9. Be happy !
  • Bruce Sun
    0 Bruce Sun over 6 years ago in reply to RFinley
    It works. I can see the part in the list when I use place command. Thanks.
