  2. Allegro X Capture CIS
  3. How To Change Library Path In OrCAD Capture 17.4
  • Replies 16
  • Subscribers 52
  • Views 73970
Bruce Sun
Bruce Sun over 6 years ago
I downloaded the symbol and footprint of a part from Ultra Librarian to a local folder. After I put the part in the schematic there is a warning as below.
WARNING(ORCAP-2434): Footprint 'CP_32_15' specified in PCB Footprint for instance 'U1' is missing. Ensure 'CP_32_15' is in the library path.
Does anyone know if there is a way to add my local folder to the library search path? I want to keep the default library folder clean and use project specific folder for symbols and footprints.
Thanks.
Bruce
  • RFinley
    RFinley over 6 years ago in reply to Bruce Sun +3
    [Allegro Footprints] only previews your footprints when you select a part. Needs to be under [Part Library Directories]
  • RFinley
    RFinley over 6 years ago +1
    First, you need to figure out where your SPB_Data folder is as that will have the Capture.ini config file you need to edit. Easiest way is to open a windows file browser, click on the URL bar at the…
  • Bruce Sun
    Bruce Sun over 6 years ago in reply to RFinley +1
    Thanks for your information. When I start the Capture CIS it shows the following line INI File Location:C:\SPB_Data\cdssetup\OrCAD_Capture/17.4.0/Capture.ini So I changed the file as below. [Allegro…
  • V kumar
    0 V kumar over 5 years ago in reply to RFinley
    Are you unable to place parts on a board or are you unable to place parts on a schematic page?
    Ans: yes same issue
