  2. Allegro X Capture CIS
  3. Capture BOM wrong
  • Subscribers 51
  • Views 13305
Capture BOM wrong
jatins
jatins over 6 years ago
Hi
i have generated a BOM of my design and one of the parts is showing wrong information than what I specified in the database. I can see that in CIS database that part has been specified a correct information  but when I exported it to bom it shows wrong values.
  • RFinley
    0 RFinley over 6 years ago
    Have you run "update part status" for the design from CIS Part Manager?     Have you created any variants that would override this part?
    I use CIP to manage the database.  So, the PART_NUMBER property is used as a SQL query, then gives you a dialog of properties that will be updated if you accept them.
    If the info is still wrong, the PART_NUMBER property points to the wrong part.  Select the schematic part and link it to the correct part to update the part properties.
  • jatins
    0 jatins over 6 years ago in reply to RFinley
    Hi
    I also used CIP for database management. I checked there is no other variant with the same Part Number.
    CIP also shows correct info but the problem is BOM.
    I haven’t yet checked updating the part status but I don’t understand why it has anything to do with the correct info which I specified with another random info.
  • RFinley
    0 RFinley over 6 years ago in reply to jatins
    Part Manager - Update Part Status verifies the part properties against the CIS/CIP database.  Ctrl-U verifies and allows you to update all parts in the design individually.
